Feedback please on GIGABYTE Z490M Gaming X and/or Asrock Z490m Pro 4
mrjayviper
I found a good price for these 2 boards.
  • Gigabyte at around $170 USD in local currency
  • $150 USD (again in local currency) for the Asrock
These are at the cheapest/cheaper end of the Z490 that's available locally. I have a limited budget hence looking for good/great value boards. There are other board in this price range. But these 2 boards have these advantages:
  • these 2 has a heatsink on VRMs on the edge of the board
  • these 2 also can with 1 M.2 heatsink
I did a net search and didn't find any review on both. I would appreciate it very much if you can share your experiences with either boards.
I plan to get a 10600k and do some "mild" (4.5-4.8 OC) paired with a AIO 360mm setup.
Thanks!
kirbyrj
Thanks!
If I had to choose between the two, I'd probably get the Gigabyte, but it's really a toss up. Both of those are on the lower end of midrange. I think you'd be fine with either for your planned setup.
