Orinthical said:SMS...
If you want free... I'd say try a logon script which launches the installer. That is of course assuming the installer can be launched with switches and/or a unattended file so the user will not have to enter anything. If the users have admin rights then this shouldn't be a problem... if they do not have admin rights then you will need to run the installer as one via the script.
The script could also check for a file or path before proceeding with the install; this way you won't call the installer each time the user logs in, it will only execute if that file/path does not exist.
annilation said:SMS requires A.D.
