This is for those who are stuck with graphics hardware that just went legacy status but want to run Windows 7 at top speed just like they did with XP/2003. Before someone shoots off with "get a new card", try saying that to those who bought laptops very recently stuck with a chipset that was not very old but nonetheless made legacy status – or making an XP net book run Win7.
Windows 7/Server 2008 R2 is definitely a nice fast OS, but Microsoft decided to clip out any 2D acceleration for any WDDM 1.0 drivers... certain recent DX9 cards (ATI) fell into legacy status and will not receive the WDDM 1.1 upgrade that restores their old 2D GDI acceleration. The way around this is to load XPDM drivers, which is easily done with the 32bit Windows. The 64bit Windows is a different beast... but it is very possible to load XP drivers and get a fully accelerated Windows just as fast as XP’s graphics engine. This affects DVD playback, Flash playback, web browsing, and also has an effect on 3D gaming when there are 2D elements present (your windows, in game FMV’s).
There are 2 options:
First being you load XPDM drivers in, regain 2D acceleration and have DX9 capabilities, and loose Aero. Note: This should only be done if the WDDM 1.0 settings down below do not work or your 2D application is horribly bogged down still and Aero cannot be enabled which acts like fully asccelerated GDI (Eg. older Autocad). The default registry settings are not optimal either way for DX9 cards.
Option 1 – XPDM install on a 64Bit OS
1. First, download your favourite XP graphics driver you know that works well on XP.
2. Extract the driver from its installer and open the driver’s INF file
3. Look for your graphics card and its corresponding PCI_ID, example:
"ATI Radeon X1200 Series " = ati2mtag_RS690M, PCI\VEN_1002&DEV_791F
4. This example has my laptop’s chipset listed, the “ati2mtag_RS690M” is our point of interest, CTRL+F and search for later occurrences of it
5. You will arrive to this point in file (for your specific card... mine is an example)
[ati2mtag_RS690M]
FeatureScore=FC
CopyFiles=ati2mtag.Miniport, ati2mtag.Display, ati2mtag.OpenGL, ati2mtag.Wow64OpenGL, Uninstall.CopyFiles, ati2mtag.OGL, ati2mtag.ORCA;, DVCR.CopyCodec
AddReg=Uninstall.AddReg
DelFiles=ati2mtag_DelFiles
UninstallFiles=Uninstall.CopyFiles
UninstallReg=Uninstall.AddReg
CleanFiles=ati2mtag.Miniport, ati2mtag.Display, ati2mtag.OpenGL, ati2mtag.Wow64OpenGL, ati2mtag.OGL, ati2mtag.ORCA
CleanReg=ati2mtag_SoftwareDeviceSettings, ati2mtag_RS690M_SoftwareDeviceSettings, atioglxx_OpenGLSoftwareSettings, ati2mtag_Mobile_SoftwareDeviceSettings, ati2mtag_MobileLargeDesktopSettings
CleanService=ati2mtag_RemoveService
6. The FeatureScore=FC line is what I added to the INF under my device’s installation section as shown above, this is what makes or breaks an INF from installing on Windows 7. “FC” is chosen so the OS recognizes the INF as an XPDM driver and to install it accordingly. If the FeatureScore is set to mimic a Windows Vista or 7 drivers (F6 and E6 respectively), the driver will install wrong and not start! More info on FeatureScore can be found here>> http://msdn.microsoft.com/en-us/library/ee229540.aspx
7. Save the modified INF and go to Device Manager, select the offending graphics card and update its drivers, answer the nag prompts from Windows as required to get it installed.
8. Merge the following dwords into your registry (I do not know of HKLM takes precedence yet... MS is very stupid setting the engine by the user... so go through the keys in HKEY_USERS and add this in... especially for .DEFAULT as this is the login screen)
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Avalon.Graphics]
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Avalon.Graphics]
[HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Avalon.Graphics]
(And ideally all other user accounts)
"EnableDebugControl"=dword:00000001
"UseDX9LText"=dword:00000001
"BreakOnUnexpectedErrors"=dword:00000000
"RPCAvalon"=dword:00000001
"RecordAvalonFile"=dword:00000000
"UseReferenceRasterizer"=dword:00000000
"SkipDriverDateCheck"=dword:00000001
"SkipDriverCheck"=dword:00000001
"DisableHWAcceleration"=dword:00000001
"MaxMultisampleType"=dword:00000000
"RequiredVideoDriverDate"="1980/01/01"
9. This forces GDI acceleration (DisableHWAcceleration was done on purpose to force the GDI hooks.. the XPDM driver will accelerate them in this situation) and all 2D speed should be back just as it was with XP. Test your 3D, it should remain quick, but I have gotten the WDDM 1.0 fully accelerated Aero mode to finally match, and Classic is 20% faster (only window drag and resize piss off the CPU - not bad).
[ati2mtag_RS690M]
FeatureScore=FC
