Fast non-ssd HD?
sdy284
Simple question, whats the fastest SATA, NON-SSD hard drives right now? Thinking about getting a fast OS drive for my new build & just want to price them out. I don't need anything over 160gb
sdy284
I've heard good things about the 500 & 640Gb Caviar Black AALS drives as well, how do those compare to the raptor?
Since their 1/2 the price
PC_User
About 10% slower than the Raptor. Raptors, IMHO, are no longer worth it from a price/performance standpoint.
Also, the new Samsung F3 1TB (using 2x500GB platters) is considered the fastest 1TB drive available. I'm sure the Western Digital 1TB Black (WD1001FALS) is not far behind.
rive22
I've got the both the Samsung & the WD Blue. I can't speak in terms of multitasking yet because I'm putting a new systems together with them and hadn't gotten a chance but I did run HD Tune for kicks and as mentioned by PC_user the Samsung is the fastest and the WD isn't far behind. My samsung tops out around 145MBps while the WD was around 125MBps I believe, give or take. Access times were similar.
If speed is your primary concern go samsung, if you want long term reliability for your important files go WD Black, they have a list long of features built into their drive that samsung can't even touch, their RMA is also better, and you get a 5 year warranty. The speed diff is also as you can see not that much. I would also assume WD Black will be better at multitasking with it's dual processor.
Also, the Samsung is a good deal quieter when seeking but there is a constant low volume high pitched whine. The WD is louder when seeking, but very quiet when not in use. Just my results so far. In terms of building my first super quiet pc soon, the WD I don't mind and will be muffled by acoustic foam in my case, the samsung hopefully will be muffled as well otherwise I'll sell it.
Impulse
The straight answer would be a 150GB VRaptor. However it costs $160, for that amount of money you'd be an idiot not to get an SSD; 30-40GB for $100-120 or 60-80GB for $180-250.
Having your OS, apps, and some games on the SSD (with the rest of them on a HDD, along w/your data), beats the hell out of not having a SSD at all... And you can use symbolic links to shift game installs around w/o screwing up the install (or even individual games out of your Steam folder). Honestly they make such a huge difference, they've literally made VRaptors irrelevant.
However if you were just looking for a single-drive option within a limited budget, then the SSD is clearly out of the question (as you'd need to buy it + a data drive), and so would the VRaptor. In that case go with a 1TB WD Black or 1TB Samsung F3 as others have suggested. You'll probably find them priced within $10 of each other... Samsung's faster (500GB platters vs 333GB), WD has a better warranty, FWIW.
Jon55
WD Black 1TB or the Samsung F3 1TB. They're pretty much the same speed, are both the fastest non-raptor/non-SSD drives, and are both around $100.
kleox64
There is a new 600GB Raptor coming out together with a 300GB variant(single platter).
The 600GB should be the launch price of the current 300GB.
PC_User
With the transition many are making to SSDs, I'm not sure how many consumers would be interested in another Raptor drive.
