Jarod888
- Dec 19, 2005
I am in the processes of putting together my new system. I won't be using a watercooling setup, so I will need some fans. Noise isn't a real factor, as long as it I can't hear it in another room. I currently have a Thermaltake Armour with 4 AeroCool XtremeTurbine-Black 120mm Case Fans (89.39 CFM @ 32.46 dBA) and a Zalman 9500. The noise level does not bother me, but my computer seems to be a little warm cpu around 43 degrees C Internal temp of the air in my case 36 degrees C.
I may end up adding a ceiling fan in my office to help dissipate heat.
My new case is a TJ07. I want to use 2 of these fans for the top exaust :
http://www.sidewindercomputers.com/de12gf.html
2 of these for the hard drive bays: http://www.sidewindercomputers.com/de12ff1.html
2 of these 92 mm ones for the back intake: http://www.sidewindercomputers.com/de92tfexhisp.html
and possibly 2 of these 80mm ones at the bottom next to the powersupply for additional intakes:
http://www.sidewindercomputers.com/de80tfexhisp.html
this probably seems excessive, but I want my computer to run cool, without the hassel of watercooling. I will be running an FX 60 on a DFI expert with 2 640MB 8800 gts's
My questions are, how loud will all these fans running at the same time be, and does the addition of each fan double the noise output?
Are there any potential problems running this many fans? I want some serious air flow, greater than 100 cfm, so if anyone can recommend better fans I would appriciate it. Thanks
EDIT
I just listened to the xvid clip of the fan and it scared my cat. She was sleeping on my arm when I hit the play button. I am thinking that 2 of those plus all the others might be a little loud. I may have to revise my building. Maybe I could step down to the ones I was thinking about using on the hard drive bays.
EDIT
