NewShockerGuy
- Jan 24, 2002
Figured I'd ask.
Are there any fans out there that are more than 12v input?
I ask because the solar panel that I am looking at roughly puts out about 19-21volts.. .I'd rather not try and regulate it down and I would only need this fan in my shed so it doesn't matter as far as leds or anyhing like that...
I don't think a 120v wall fan would work for home theater applications but just wondering if there is a 120-160mm fan that can take more than 12v's without frying?
the use of this fan is to exhaust the hot air out of the shed, so really when the sun is out the fan can be on and when the sun isn't out the fan would be off, pretty simple design but just wondering what's out there...
Thanks,
-Nigel
Thanks,
-Nigel
