silentsammy
- Feb 4, 2006
Just built two new puters with the EVGA 680i SLI NF63 mainboards.
When I flashed the mobo's for the two, one of them now has my main case 120 mm fan running at 100% all the time now, which is unfortunately DAMN loud! I went into the bios and it calls this fan 'case fan #2 now' and is not the main case fan (which would have the dynamic control). The other mobo which I flashed with the same file didn't make this change.
So would you guys recommend that I re-flash the bios again? Or will a program like 'SpeedFan' be more than sufficient?
