I'm planning to move my existing HTPC into a Silverstone GD09: http://www.amazon.com/Silverstone-T...=UTF8&colid=6AMHT4ZMNLMA&coliid=IVCZTJ3SVM9UT
I need some recommendations for quiet fans that will basically max out the cooling performance of the case while maintaining a low noise threshold. Essentially, I want the "best" silent fans I can buy. I think I need two 120mm fans and two 80mm fans.
Also, the HTPC is currently using a Corsair H50, but I'm not sure the rad for the H50 will fit anywhere. Does anybody have experience with an AIO cooler that will fit in the GD09?
Thanks.
Thanks.
