Hey guys, hope to get your advice on the airflow here, especially the fans arrangement. Not sure if I did it right. I have Define R5 with two GP-14 case fans on the intake and one same GP-14 case as exhaust. Basically stock config with added fan in the front. I had my Cryorig A80 mounted to the top before, but decided to move it to the front and put moduvents back for less noise. However, I'm not sure if my decision to leave Cryorig QF140 fans (technically they have higher rpm and airflow numbers than GP-14) on the inside of the case and rad in push configuration was correct or not for better temps. My GP-14 fans are controlled by case controller and set to max. QF140 fans are PWM fans on standard Asus fan curve set in UEFI. Pics http://imgur.com/a/gLyVF
