On my son's PC, have installed Fallout3 and patched up to 1.6, and with system specs below I would think he would be getting a better framerate than 30's and lower?
everything is stock
WinXP 32bit
CPU: Q6600
Video Card: 8800GTS
EVGA 750i (using RealTek onboard for audio)
Dell 1905 monitor
latest drivers for all
I've reinstalled, updated drivers (and cleaned in between w/driver sweeper) but with everything cranked down and at 800x600, best peak framerate is low 30's. What's odd is I can crank the resolution up to max of 1600x1200 and still get same framerates.
I'm running a Q6600 o/c'd to 3Ghz and running a GTX260 with everything cranked, and I would think he should be getting something better than 30fps in comparison with the differences in systems. I will have him load up Oblivion and see if it's the same deal, as he was able to run that fine in the past and uses same/similar engine.
Looking for some advice here, as I talked him into getting it for the PC instead of the 360 and now may have stuck him with an unplayable game.
Thanks!
everything is stock
WinXP 32bit
CPU: Q6600
Video Card: 8800GTS
Dell 1905 monitor
Thanks!
