I live in the UK.
My mum wants a new computer and she would prefer a desktop to a tower.
Her current machine has a SSD (retrofitted by me, partly to improve performance) and I wouldn't want to give her a downgrade on that. The main reason for replacing the computer is stability, it crashes randomly and we haven't been able to put a precise finger on why.
The machine is used to run a web browser, office and a few other things but nothing is particularly intensive. Current machine is an old dell dimension. probably a late P4 (possiblly a pentium D) though I don't have the exact specs to hand,
I will consider either buying or building.
Specs:
reasonably modern dual core intel processor (intel for cool queit running).
SSD boot drive, 128GB should be more than enough
Ability to accommodate a 3.5 inch hard drive if more storage turns out to be needed.
Reasonable amount of front USB
Media card reader.
Full-sized optical drive (not a laptop drive).
Smallish desktop (sit under the monitor) form factor. Not looking for super tiny.
Ability to support two screens, one DVI, one VGA.
Windows 7 pro (need XP mode for a handful of win16 apps)
Probablly 8GB of ram.
The dell optiplex desktops would mostly fit the bill. However while a SSD option is listed it's highly overpriced and it won't actually let me select it on the dell UK small buisness site (it claims that the "cables and brackets" are wrong but then won't actually let me change those). Furthermore it seems even if I could and did order that option that the case can't (officially at least) support both a 2.5 inch and a 3.5 inch drive at the same time.
Specs:
Media card reader.
