I need some help here. I'm have a PC that has XPPRO with SP2 on it. It is on a WD 60gig drive that is slowly failing. I have a Maxtor 60gig that I'm trying to ghost over from the WD 60gig. I open up ghost 2003 in windows & choose Clone. The WD is 2 partitions. I choose to clone the whole drive over to the Maxtor. It reboots & drops to PC Dos & does it's thing. It then reboots back into windows. I check both drives everything looks like a mirror image. I shut down & disconnect the WD drive & make the Maxtor the master. I reboot & this is the error message I get.
"Windows could not start because of the following ARC firmware boot configuration problem: did not properly generate ARV name for HAL & system paths.Please check windows docs ...."
What did I not do right here? I know the Maxtor is a good drive.
