Hello,
Selling a Sony VPL-CX10 Projector (Projection TV, Large). Sells for about $3,000. Comes with remote, Cords and carrying case. This projector is it good working condition. Make me offer on price, I was hoping for about $750. Pretty good price . I am in Orlando FL and will accept Paypal,Money Order or check.
PM me for offers
[email protected]
AIM: PaulyPaul
Phone: 407-468-4646
Infomation:
The VPL-CX10 is a small, portable three panel LCD projector with native XGA resolution and 1200 ANSI* lumens brightness. Mounting holes make it possible to mount this projector from a ceiling, but the small size and light weight of just 7.7lbs allow it to be taken on the road. In either setting, the performance is first class; 1200 ANSI Lumen brightness coupled with native XGA resolution combine to make stunning, bright, detailed images. Add the full color experience derived from a three panel LCD projection engine and the performance is simply stunning.
Excellent picture quality using 3 panel LCD technology
Three panel technology allows multiple colors to be reporduced all the time resulting in color saturation that does not vary with image brightness. You get bright, vibrant color all the time
High Light Output Of 1200 ANSI Lumens
High brightness counts when you are projecting in an area where the lighting can not be controlled, or when you are projecting onto an extremely large screen. With a brightness of 1200 ANSI lumens, the VPL-CX10 can project in bright rooms and onto screen with up to a 300" viewable area (measured diagonally).
Native XGA Resolution
High resolution is enabled by three LCD panels, each with 1024x768 pixels. As a result, the VPL-CX10 will preserve the original desktop image and resolution of XGA laptop computers.
Compact, lightweight, and flexible
A retractable carrying handle is easy to reach for outstanding mobility. Can also be used in a variety of installation situations - ceiling, floor or rear projection.
Supplied remote control
The RM-PJM10 remote control provides the digital zoom function and control over the on-screen menu. In addition this handy remote performs the functions of a computer mouse for wire-less control during presentations.
Set-up flexibility
A new height adjuster, as well as the integrated digital keystone function help make setup fast and simple.
High resolution and flexible input capability
Accepts up to SXGA with a horizontal frequency of 15 to 91 kHz, Composite video, Y/C video, component video and 15 k RGB video signals.
Projector Station Software
PROJECTOR STATION version 2.0 software makes your projector computer friendly via the USB port connector by allowing your PC to control brightness, contrast, input selection, and many other useful controls. It can also configure the projector remote so that an entire presentation can be launched with just one button.
Quiet operation due to low fan noise
Makes it possible to communicate for hours without fatigue.
Impressive stereo sound with the built-in stereo speakers
Makes it possible to project with sound reinforcement for a complete multimedia experience.
Carrying Case
An attractive carrying case is supplied which is large enough to fit both the VPL-CX10 and a laptop computer.
Projection System
3 LCD Panels, 1 Lens
LCD Panel
0.9-inch p-Si TFT LCD panel (786,432 pixels x 3)
Projection Lens
1.3 times zoom lens, F1.7 to 2.1, f33.6 to 42mm
Lamp
132W lamp
Screen Coverage
40-300 inches (viewable area, measured diagonally)
Light output
1200 ANSI Lumens
Color System
NTSC, PAL, SECAM, NTSC4.43,PAL-M,PAL-N
Resolution
Video: 750 TV lines, RGB: 1024x768 pixels
Acceptable Signals
RGB (fH: 15-91 kHz, fV: 43-85Hz) 15kHz component 50/60Hz system, composite video Y/C video
Speakers
Max 0.5W x 2 (stereo)
Power Requirements
AC 100 to 240V, 50/60 Hz
Power Consumption
Max 210W, Standby approx. 5W
Operation Temperature
0-35C, 32-95F
Operation Humidity
35-85%
Dimensions
285(W) x 90(H) x 249 (D) mm, 11 1/4 (W) x 3 5/8 (H) x 9 7/8 (D) inches
Mass
3.5kg, 7lb 11oz
Also have a 5.1 Surround Sound System and DVD player (with subwoofer) that works with the Projector GREAT. Full System right here Take it all for 1,200
PM me for offers
[email protected]
AIM: PaulyPaul
Phone: 407-468-4646
Infomation:
Set-up flexibility
Carrying Case
Projection System
LCD Panel
Projection Lens
Lamp
132W lamp
Screen Coverage
Light output
1200 ANSI Lumens
Color System
Resolution
Acceptable Signals
Speakers
Power Requirements
Power Consumption
0-35C, 32-95F
Operation Humidity
35-85%
Dimensions
Mass
3.5kg, 7lb 11oz
