buschman31
- Nov 8, 2005
I have two laptops that are in my garage that I dont use or need. Both have G1 mobile processors. I would be willing to take an offer for both laptops.
Fujistu Lifebook AH550 $45 plus mailing costs
comes with 500gb hdd w/ no os or power supply. charging port is missing its cover.
the laptop will have to be manually turned off using the power button.
i3 330m chip
has hdmi
not sure of the battery life but assume that a replacement is needed.
no Windows 7 coa cause the sticker is no longer readable
http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=TECHSPECS&Series=A%20Series&Model=AH550&ProductType=Notebook%20PC
Dell D6410 $45 plus mailing costs
https://imgur.com/a/260B2w3
comes w/ no hdd has broken screen but it has been tested and will post and boots into Windows.
The control key is missing.
the display can be easily removed and the laptop can be connected to a monitor to be used as a temporary desktop. it does have a Windows 7 coa. not sure of the battery life but assume that a replacement is needed.
power supply is included
https://www.cnet.com/products/dell-...20m-windows-7-pro-2-gb-ram-250-gb-hdd-series/
i3 330m chip
has hdmi
