What really increases PPD the most generally speaking a generational CPU upgrade or a generational GPU upgrade?
I have a lot of fun playing BF3, and a GPU and CPU upgrade for F@H and BF3 interests my mind a lot. I would like to work in the medical field someday myself and helping cancer and Alzheimer research for Stanford University falls in line with these goals as well.
I Downloaded latest client last nite after an intense BF3 session. As you can see, I like the changes made to the F@H client. (it is VERY USER FRIENDLY unlike the past versions imho) Anyhow my system is a AMD Rana X4 @ 3.875 GHz. DDR3 @ 1666, and I have been running my 560ti @ 920MHz Core. (Because it keeps it under 80* degrees which I prefer, CPU runs @ 70*) I'm right around 20k PPD with this setup I'm led to believe. Here is a picture of it running. FYI PPD estimation is listed near bottom left hand corner of the F@H client in picture/screenshot.
I would like to know what CPU/GPU setup would double the PPD? (From 20kPPD -> 40kPPD score)
Also what about just putting in a 680GTX vs the 560Ti I currently have? How much should PPD increase with my setup just updating the GPU? My 560Ti runs BF3 between 60-90fps fully maxed out setting on my screen which is a 720p resolution capable of 120HZ. So more FPS would be noticeable there also, better minimums and better highs. (Its memory usage even peaked usage around 1750MB memory! I've never seen BF3 use so much memory usually 1200-1500 anyhow....)
Likewise just a CPU recommendation is important, because it would increase F@H performance and BF3 performance from what I've been hearing? Another important feature from the CPU would be lowering (full load temps) from F@H CPU temps because I am right at the thermal threshold for my setup, but it runs no problem. It just increases the rooms temperature obviously. So a CPU that would lower current temp noticeably, and get 2x PPD or close would be nice option if avalable. Any CPU's on the market today for this combination of goals, better BF3 gaming and cooler+more PPD in F@H? Any ideas with links/pictures to prove performance that's what I would like to find? Anyone have a setup similar to mine running F@H on Windows with a more modern CPU and/or GPU that can screenshot it so I can compare its estimated PPD figures here @ [H] I hope?
My BF3 temps are around 60* on the CPU when loaded, and F@H is around 70* on the CPU when loaded. What temperature is an Ivy Bridge Quad core run @ full load with F@H for instance, what is the PPD?
Like I stated earlier...What really increases PPD the most generally speaking a generational CPU upgrade or a generational GPU upgrade?
Please don't flame my post I just simply want to be more educated on this topic for my next system upgrade planning, tia.
