Eyefinity monitor arm?
vjcsmoke
Anybody can recommend a monitor arm for 3 monitors to display 3x1 in Eyefinity? Just looking to see what's out there and how much it would add to the cost of the setup.
UL
how about recommending displays... :( im not sure my brain can handle this
lt_shiro
Dell P2310H ($210) or U2410 ($400 i think) as they build in height-adjustable stand and tilt, swivel and pivot features.
edit they also have display port for eyefinity
arms that can mount 3 displays cost about $150-$200,
Threader
Depends what you are looking for? The one I bought from amazon was inexpensive but limited in the sense that it will fit a MAX 3 x 22" Wide screen LCDs but at a cost to flexibility. the flexible arms are totally stretched out so I can't really curve/tilt in the outside panels at all. Still for around $100 Shipped it's a solid piece of hardware. Though it clearly was engineered for small diameter panels.
http://www.amazon.com/gp/product/B0023ED22Y/ref=ox_ya_oh_product
Dual
The largest 3 way monitor stand I can find only does 20" monitors.
I thought these would be easy to find...
Threader
They must have changed the arm in back or added another extension at added costs for 3 x 24"
