Extreme Instability using Remote Desktop
Discussion in 'Operating Systems' started by lightsout, Dec 28, 2019.
  1. lightsout
    lightsout [H]ard|Gawd
    1,079
    Mar 15, 2014
    I have used Remote Desktop literally for years and basically everyday to connect to my headless media server.
    Today when connecting to it I am having all sorts of issues.
    I am either losing the signal to my monitor, which I thought was the cable or a loose port.
    Or the system will freeze, the mouse still moves, but its locked up. Ctrl alt del or alt tab does nothing.
    It is for sure RDP thats doing it. The system is fine until I log in to the other PC. It may happen instantly it make take 5 minutes, but its happened about 10 times today.
    My main PC is updated, both running win 10, the server has updates disabled.
    Any ideas. I did something I found through google with gpedit.msc, didn't work.
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    15,460
    Oct 7, 2000
    have you rebooted everything including the modem/router?
  3. lightsout
    1,079
    Mar 15, 2014
    Yes I have. It's at the point now that instantly when I last connected the system froze. But really odd as the mouse still moves.
    I don't at the moment have a second PC. I will tomorrow when my ram comes back from RMA. Will try from another machine.
    pendragon1 likes this.
  4. Snowknight26
    Snowknight26 [H]ardness Supreme
    4,202
    May 8, 2005
    Does the server have a GPU? What RDP version is being used for the connection (might have to check event viewer for that)? Have you tried with RDP hardware acceleration turned off? What specific group policy changes did you make that didn't work?
    The reason the mouse moves is because it's rendered on the guest side, not on the host.
    Just to be clear, you mean that the guest machine freezes, not the host that you're connecting to, correct?
  5. lightsout
    1,079
    Mar 15, 2014
    Does the server have a GPU? Yes 1050ti
    What RDP version is being used for the connection (might have to check event viewer for that)? No idea would have to figure out how to check.
    Have you tried with RDP hardware acceleration turned off? Didn't know that was a thing. Don't see it in the standard RDP options.
    What specific group policy changes did you make that didn't work? This but it was probably irrelevant?
    https://social.technet.microsoft.co...ection-is-established?forum=win10itprogeneral
    Thanks for your help man, really pulling my hair out on this one.
  6. Snowknight26
    4,202
    May 8, 2005
    When connected, right click in the RDC client title bar and select Help -> About, it should show you the RDP version being used.
    Since I'm still not sure if the guest or the host is freezing, try updating your GPU drivers (on whichever is freezing). Additionally, watch the clock of the machine and see if it keeps ticking. If not, try Ctrl+Alt+Shift+Win key+B (resets the display adapter).
    Alternately, disable hardware acceleration via GPO: Computer Configuration -> Administrative Templates -> Windows Components -> Remote Desktop Services -> Remote Desktop Connection Client -> "Do not allow hardware accelerate decoding" = Enabled
    I'll have more suggestions once you let us know which machine freezes.
  7. B00nie
    B00nie [H]ardness Supreme
    8,132
    Nov 1, 2012
    If you haven't updated the server but updated the client, chances are you run incompatible OS versions. Microsoft made changes to RDP not too long ago that may have broken backwards compatibility. RDP is not very safe to use anyway, you should at minimum block it from wan side in your router.
  8. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    You should 100% block all RDP ports open to WAN, open RDP ports are the equivalent of bending over for the soap in prison.
    B00nie likes this.
  9. lightsout
    1,079
    Mar 15, 2014
    Well that sucks about the open ports because I use it when away from home. Is there a more secure way to do that?
    And it is the client machine that is freezing. Server not being affected.
  10. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Never open RDP ports to the interwebz. Use AnyDesk, it's free and it's great - Or set up a VPN and log into your RDP desktop from there.
    If you monitored that port for hits you'll see it getting smashed while hackers try to brute force it - I've seen it so many times.
    weav2k likes this.
  11. lightsout
    1,079
    Mar 15, 2014
    So I disabled RDP ports and installed anydesk. Seems like the software is pretty hit and miss. Most the time I get stuck at the "loading image" screen. This is over a gigabit network that I don't have any other problems with. Finally uninstalled it because I was getting annoyed at it not working.
  12. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Really? I use it for everything under Windows, MacOS and Linux as a PC tech and never have a problem with it.
  13. lightsout
    1,079
    Mar 15, 2014
    Yeah it was weird, maybe I need to try it again. I think it may be having an issue, that when I logout of RDP, there isn't a user logged in, and sometimes that throws it off.
    On a side note I used my laptop to log in and had no issues. Think I need to update the server but I used some program to kill windows updates and can't find it to reverse them lol.
  14. lightsout
    1,079
    Mar 15, 2014
    When I login with anydesk while I am connected via RDP, it kills the RDP session, and then I see the windows login screen, when I push the little icon on the bottom right it starts to login and then sits there.
    When I login withouth being connected via rdp I just hang at "conected, waiting for image".
    I think the problem is that there is no user logged in at this point, but shouldn't it still be able to log in?
    EDIT## Apparently it doesn't like a machine with no monitor but there is a workaround.
    Send "ctrl alt del", hit cancel, select "auto adapt screen resolution", and you should be in.
  15. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Hang on...
    You don't use AnyDesk 'with' RDP, you use AnyDesk in place of RDP. You install AnyDesk on the server and note the 'AnyDesk Address' and you install AnyDesk on the client and connect to the Remote Address using the AnyDesk Address.
    You don't need to forward any ports and things are vastly more secure than RDP open to the world.
    B00nie likes this.
  16. lightsout
    1,079
    Mar 15, 2014
    Sorry that sounded weird. I understand you don't. I just had to RDP to get anydesk installed. And was using it to get back into the server while I was having issues. So I was trying a variety of things.
    Looks like I have it able too work now. As stated in the above edit.
    Mazzspeed likes this.
  17. x509
    x509 [H]ard|Gawd
    1,911
    Sep 20, 2009
    Hey, I'm interested in setting up a machine with no monitor. Tell me more. Wiill anydesk run on Win XP?
  18. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Oh Gawd, I don't think any modern software will run under Windows XP... :D
    B00nie and AltTabbins like this.
  19. AltTabbins
    AltTabbins [H]ard as it Gets
    19,585
    Jul 29, 2005
    Having xp connected to anything internet facing is a bad idea anyways.
    B00nie and Mazzspeed like this.
  20. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Oh yes. RDP open to the interwebz and Windows XP could be something worse than bending over for the soap in prison... If there is anything worse than that?
    XP > Concrete bunker > Faraday cage > No internet = 50% secure.
    B00nie likes this.
  21. B00nie
    8,132
    Nov 1, 2012
    Note that Teamviewer is also free for personal use and you can set up an unattended access via a password. I use it to administer my father in laws linux desktop 3000km away.
  22. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    Yeah, but their licensing sucks and they're obviously spying on sessions in order to work out if people are using their product for personal use or not - And their software under Linux is a 100% fail with fractional scaling, the only software that looks like a total mess with 1.5 scaling @ 4k.
    Screw 'em. AnyDesk all the way!
  23. B00nie
    8,132
    Nov 1, 2012
    I doubt they are spying on sessions, at max monitoring the frequency of your connections and triggering alarms if it starts to look like a job not a hobby. If they would get caught spying they would lose all their corporate customers instantly.
  24. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    I don't know B00nie. The only way you can really tell if someone is using the product for personal or business use when you're logged into an ordinary users machine is to spy on sessions - There's no server OS involved, no business related software, nothing to raise a flag that their software is being used in a way that isn't approved.
    I'd pay for a license, but the cost is unrealistic.
  25. lightsout
    1,079
    Mar 15, 2014
    From my quick testing team viewer has the same problem. Doesn't like a computer that doesn't have a monitor.
  26. AltTabbins
    19,585
    Jul 29, 2005
    Ive been a big fan of Chrome Remote Desktop. It has a browser client and works just as well as Teamviewer for me.
  27. Kardonxt
    Kardonxt 2[H]4U
    3,064
    Apr 13, 2009
    Install the monitor driver under advanced options. You would also want to enable allow windows logon in security.
  28. lightsout
    1,079
    Mar 15, 2014
    I went back to anydesk. Seems like I got it doing what I want.
    Mazzspeed and Kardonxt like this.
  29. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    I evaluated Chrome Remote Desktop when I dumped Teamviewer, but there was something stopping me from using it, I can't remember what it was? Perhaps the inability to remotely reboot and log back in?
  30. B00nie
    8,132
    Nov 1, 2012
    For me the best way to remote connect a desktop is set vnc with -nolisten tcp flag and SSH in. That way you don't even need to set up a full desktop environment.
  31. B00nie
    8,132
    Nov 1, 2012
    I'm not an advocate of Teamviewer in any way. I use Gotomeeting for all my remote sessions. It's only limitation is that you can't do file transfers but that's not a problem for me. I can access all the assets I need online.
  32. lightsout
    1,079
    Mar 15, 2014
    Thanks for the anydesk recommendation. I am getting 4 different PC's hooked up with it. Pretty nice just in case I need to jump on my work PC or mess with the HTPC from my office.
    Much better since it doesn't mess with the logged on user like RDP.
  33. x509
    x509 [H]ard|Gawd
    1,911
    Sep 20, 2009
    Actually this system would be used for just a short while, and would be connected only to my home LAN, not the internet.
  34. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    But...Why XP? Surely there's options other than XP?
  35. x509
    x509 [H]ard|Gawd
    1,911
    Sep 20, 2009
    Long story short, I have this very old system that has the extended PCI slots and I have an adapter card that needs these slots. I need to read some very old backup tapes. The system runs Win XP. It's a short-term thing. Once the tapes are all read, I get rid of this system, unless someone wants the motherboard.
    See the bottom of this thread. https://hardforum.com/threads/looking-for-project-dual-cpu-sli-motherboard.1990627/
  36. Mazzspeed
    Mazzspeed 2[H]4U
    2,438
    Dec 27, 2017
    I've got a DAT backup tape that I need to recover with pictures of my late Father after the HDD the pics were on failed - I totally understand.
    I really need to rig up something like this.
