Extract audio & image from a PC --> 4 TVs + amp + speakers
lauraparis
Hello,
I'll open soon a small fitness center in France, and here is my installation:
- 2 x 75'' LED TVs at left of the room with 2 x Martin speaker and 1 Martin sub.
- 2 x 75'' LED TVs at right of the room with 2 x Martin speaker and 1 Martin sub.
Only videoclips will be played on the 4 TVs. The TV will always play the same thing at same moment. The synchronisation must be perfect between the 4 TVs, and of course, with the audio. The DSP Martin DX0.5 will allow, I think, to manage the delay between the sound and the image, I'll tune it once and for all.
All will be controled by my PC, with Windows 10.
My problem is that I don't know at all how to do with my PC.
- my mothercard is a "Gigabyte B360 HD3"
- my graphic card is "Gigabyte GeForce RTX 2060 Windforce OC 6Gb"
What I want to do is splitting my PC monitor in two: on the left part of the monitor, I want to see my normal desktop (to check my e-mail, control my .mp4 playlist, etc.), and on the right part, I want to see the videos, exactly what my clients will see. Of course, I never want that my clients see the mouse pointer, texts, etc., I don't want that they see what I'm doing: only videos for hours and hours.
Splitting my PC monitor like that is possible?
Am I right about these connexions?
- PC monitor plugged to the Graphic Card DisplayPort.
- HDMI Bluestream splitter plugged to the Graphic Card HDMI port.
- Focusrite plugged to the Motherboard green sound Realtek output?
The resolution of my videoclips will be all different, sometimes 1080p, sometimes 720p, maybe 4K. Is it possible with my playlist that all is automatic and that the image size automatically adapt to my 75'' TVs?
Thanks so much for the help, I'm really lost in that last step of my project! :)
Laura
vxspiritxv
You could always go direct, your current video card will work, use screen mirroring, convert the non hdmi ports to hdmi ports. AmazonBasics High-Speed Fiber Optic HDMI Cable for the runs.
Now if you need a 5th (local) display, see if you can add a second video card, otherwise a cheap USB to video will work, just don't expect to game on it, and don't use it for video replication; It's USB and will eat CPU cycles.
Zedicus
i like using hdmi splitters when doing large rooms. even if the videocard has enough outputs. it actually simplifies using the pc, and the splitters usually provide an hdmi amp. it will drive a lot longer hdmi cable then a videocard direct connection will. you should be able to use something like mediaplayer classic to build out a playlist of your items, set it to loop, and let it handle the resolution and screen size so that the TVs always show a full screen (or very close) image.
dont worry much about the audio delay unless it is way out of wack, in a large enough space sound from multiple sources will never be perfect as you walk around the room. most HDMI splitters will pass audio, why not just let the audio come out of the TVs anyway?
lauraparis
Thanks to both of you, after reading you, I have continued to find information about all of that...
I still have a doubt about sound extraction.
What is the best solution to extract sound (ampli will treat the delay with image) with the best sound quality possible:
A) Directly from the computer with a Focusrite (USB) ?
B) From the audio output of the Bluestream HDBaseT splitter (in that case, 2 options: digital coaxial OR analog L/R) ?
Some shops told me that A) was better than B), and other than B) was better than A)...
Thanks a lot! :)
Laura
Zedicus
how big is this room? i would (usually) do something like this, unless they have a dang good reason not too. always remember KISS.
lauraparis
The room is 500 m². Two TVs (with one left speaker to the left of the TV duo + one right speaker to the right of the TV) will be close each other in a part of the room, and the two other TVs will be together to another side. That's why your suggestion doesn't work, but thanks a lot... :) I really have to keep my configuration. My only concern is about A) vs B)
