Okay, I really want to go to a watercooled setup mainly on my CPU. I want to cut down on the noise my PC makes so I think this is a good move towards getting rid of all the fans in my case.
My problem is that I can't run an internal water cooling setup. I simply have too much hardware inside my case and not much room to fit a pump, reservoir and radiatior.
That being said, I'm considering the Evox kit from Koolance or the Corsair kit. Are there any others out there that I should be looking at and does anyone have any first hand experience with either the Koolance or the Corsair. I did read the reviews here on both kits and the Evox looks like the better of the two.
Any help would be appreciated.
