External drive not working - can USB drive read multi-partition drives?
Discussion in 'SSDs & Data Storage' started by tankman1989, Apr 19, 2012.
  1. tankman1989
    tankman1989 Gawd
    585
    Aug 21, 2009
    I have an external drive enclosure that I just bought and I can't seem to get it to detect on any machine. I did originally have just one partition on the drive but then re-partitioned it with 3 different ones. Will this work over a USB 2.0 connection? I can't remember if partitioned drives are detected over USB.
  2. thedge
    thedge Limp Gawd
    273
    Dec 8, 2010
    Yes it will work fine.
  3. dustNbone
    dustNbone [H]ard|Gawd
    1,032
    Apr 7, 2009
    The partition structure of the drive shouldn't have anything to do with the interface, they're a couple of layers apart. The enclosure could just be faulty, or it's power supply, or the USB cable.
  4. tankman1989
    tankman1989 Gawd
    585
    Aug 21, 2009
    Thanks. I tried 2 USB cables so I don't think it is that and I know the drive works in other machine.. Frustrating.
  5. MrGuvernment
    MrGuvernment [H]ard as it Gets
    19,169
    Aug 3, 2004
    so then likely the enclosure then :)
