External 3.5" HDD box connected to USB4/Thunderbolt - shall I still need a power cord?
Coolio
[CORRECTED: I called it initially 3.5" SSD by mistake, it is HDD of course!]
Hi guys,
my NUC's internal storage capabilities are limited with M.2 and 2.5" SSDs, which are not cheap, so I want to move the maximum of data to the external 3.5" HDD.
Since 3.5" disks need an extra 12V power, which MiniPCs can't provide them with, self-powered boxes like "********** USB 3.0 External Hard Drive Enclosure for 3.5/2.5 Inch SATA Hard Drives" [Amazon's link gets deleted :unsure:] help to solve this problem.
However, my NUC has a Thunderbolt-enabled USB4 with Power Delivery, which (as per TB spec) should deliver at least 15W.
If I connect my HDD to the aforementioned USB4 port, shall I still need the self-powered box, or finally not?
Thank you!
Luke M
You said SSD but I'm guessing you mean hard drive?
I haven't seen anything that supports Power Delivery, but I haven't really been looking either.
Coolio
no, its still only 5v, afaik. youll need a powered enclosure.
Wiki says that yes, 5V is the minimum for USB4, but can be up to 20V and even 48V - so I will ask Intel support for that. As for Thunderbold spec (since my USB4 is TB-enabled), looks like it doesn't exceed 5V, but maybe someone from HardForum can have a look at pages 9-12, as I'm way too far from electricity.
