SugarCoatedSour
- Dec 26, 2004
Ever since I unzipped a zip file from the temp folder, explorer seems to crash every time I click on a certain shortcut within that folder.
This seems to only happen in two locations, and it only began after I unzipped this folder. It has happened on two other occasions, but I can't quite remember how the problem was fixed--if it was fixed at all.
Has anyone else encountered this problem? If so, what would be my best solution to fix it.
Right now I'm running on Windows XP Pro SP2 with the Neowin UXTheme.dll hack for visual styles. Not sure if that's important or not, but I thought I'd post that info up.
Many thanks in advance
