Explorer Crash - Keeps coming back - Please help
Discussion in 'General Software' started by marley1, Aug 31, 2004.
  1. marley1
    marley1 [H]ardness Supreme
    5,447
    Jul 18, 2000
    Alright i posted a few days ago, since then i formatted and got rid of sp2. SO one crash down and a new one.
    When i right click on some folders. I will get a Explorer Crash then a Internet Explorer Crash.
    the explorer crash is
    AppName: explorer.exe AppVer: 6.0.2800.1106 ModName: shell32.dll
    ModVer: 6.0.2800.1106 Offset: 00048062
    then after that this error comes up
    an error has occurred in internet explor. internet explorer will now close.
    Anyone have any idea how to fix? I got rid of any BHO that didn't look needed specifically one for DAP(download accel plus) and one for Adobe.
    Any advice here?
    Thanks,
    Dan
  2. gamer1drew
    gamer1drew [H]Lite
    98
    Jul 17, 2004
    Hmm I doubt this will help, but could it be bad ram? Anytime I get explorer crashes after a reinstall its either driver problems or hardware malfunctions.
  3. wallijonn
    wallijonn Limp Gawd
    302
    Jul 24, 2004
    can you extract shell32.dll from the install CD to a temp folder, reboot in safe mode, then copy it to where the original shell32.dll is?
    what's the command to check system file integriy, sfc /scannow?
  4. marley1
    5,447
    Jul 18, 2000
    any other options
    right now i just ran spybot and spysweeper
    uninstalled download accel plus since spybot found it to have like 10 ads.
    updating everything right now and rebooting.
    ill reply back in a few
  5. marley1
    5,447
    Jul 18, 2000
    none of that did anything.
    what else can i do?
    still didn't try that shell.dll but i would rather try that last since i cant afford to format again.
    i thought it was my usb hdd so i turned it off, nott hat. turned of some creative program loading up still no good.
    what else can i try?
  6. Major_A
    Major_A [H]ard|Gawd
    1,164
    Jun 15, 2004
    Do yourself a favor and get Firefox.
  7. marley1
    5,447
    Jul 18, 2000
    i dont see how firefox will fix this problem.
    i right click on desktop folders and this crashes.
    seems like its a windows problem not browser related.
  8. marley1
    5,447
    Jul 18, 2000
    well im getting closer.
    i just remember i never installed the drivers for hte sata raid controller which i dont use. ijust have a normal ide drive. but i installed the drivers.
    now its only crashing 1 time, before it took like 4 times then it would be fine.
    any one experience this problem?
  9. Major_A
    Major_A [H]ard|Gawd
    1,164
    Jun 15, 2004
  10. lil layzie
    lil layzie Gawd
    755
    Jan 7, 2004
    OoO, I know. It's most likely Spybot. I had this problem myself and it took me a while to figure out, but once I did, the problem went away.
    http://www.hardforum.com/showthread.php?t=799510
    ^Read the 2nd last post in that thread. Hopefully that will fix it. Good luck.
  11. darktiger
    darktiger [H]ard|DCer of the Month - April 2007
    11,819
    Apr 10, 2003
    Did the problems happen after you installed SP2? Might want to bring up task manager to see if something is taking all your system resources. I know that WinBlinds made me get that same messege....
  12. marley1
    5,447
    Jul 18, 2000
    good shit brotha. i just tried that since i had spysweeper and i think it fixed it. thats wierd never would thought that would cause its not even loaded with startup.
    This did happen after sp2, but i wonder if this would now solve that problem in sp2. I formated and im on sp1. SP2 had shit with my usb printer wouldn't allow me to scan, so sp2 is gone till its all fixed.
    Well so far i think its fixed
    Thanks all for replying.
    Thanks again,
    Dan
