Hi,
I have been experiencing data corruption on my OS drive after long shut down periods. (want to conserve power?)
What usually happens is if I shut down my computer for what seems to be more than 12 hours, the moment I turn it back on a few programs will crash on the startup. If I leave it off for longer, programs will keep crashing even after trying to open them, and I will get a BSOD I believe stating.. "Page fault in non-paged area" or something to that extent.
I've run chkdisk, error checking and memory tests and all come back stating that the hardware is fine.
I've sinced changed to AHCI and removed my raid array.
I would like to note that leaving on the computer has zero problems, and restarts are fine as well.
All windows updates.. all up to date drivers as well.
Here is my setup:
AMD Phenom II x4 945
Biostar TA880GB+ (05/24/2010 bios)
PSD34G1600K Patriot DDR3 2x2gb 1600mhz
NVIDIA Geforce GTX 460
Intel 80gb SSD x-25m (ssdsa2m080g2gn) OS drive SATA
WD 1.5 TB WD15EARS-00Z5B1 (storage) SATA
WD 2TB WD20EARS-00MVWB0 (storage) SATA
Samsung 1.5TB HD154UI (storage) SATA
HL-DT-ST BDDVDRW GGC-H20L (blu ray player) SATA
any help would be appreciated, thanks!
Here is my setup:
