Cerulean
- Jul 27, 2006
Greetings,
I am trying to figure out how to create a shared calendar and to access it. On a basic level, it's easy and I am able to do it, but consider this scenario:
I have stuff in my Exchange calendar which is not shared (meant to be private). I create another calendar and I share it with my test user. My test user accepts the invitation to the shared calendar, but mistakenly removes it from their Outlook and has also deleted the invitation e-mail they received. According to the permissions of the shared calendar, they still have permissions to do stuff on it. But when my test user adds my name from Active Directory using the "Add Calendar --> From Address Book" context menu option, it doesn't present them with any choices of which calendar to add -- it adds my Exchange calendar and shows all my entries but replaces all my entries with a text that reads "Busy".
Let's assume that I'm gone. In fact, I get terminated. What happens to the calendar that >I< created and shared? Unlike a shared mailbox, doesn't my calendar stop working too?
Basically, in my real situation, I am needing to setup a shared travel calendar operated by the secretary in the Executive department that will be read and accessed by personnel from all over the company. Should the secretary retire, it would be messy to deal with transitioning the calendar / deactivation of user account. Is it not possible to have a "Shared Calendar" on the same level as "Shared Mailbox" (accountless / owned by the system)?
