SJConsultant said:I have installed trial version of Vamsoft's ORF on two Exchange Servers so far.
With that said greylisting kicks major ass!
Within two days both servers rejected over 4000+ emails *each* as being SPAM just using the greylisting functionality. What emails do get through also get checked via RBLs, SURBLs, reverse DNS, and a few other compliance checks.
With pricing at $200 per email server (no mailbox limit) you just can't beat the price and functionality.
swatbat said:That software doesn't look to bad. Cheap too which is a plus.
Most of our severs are running GFI for antispam. Works pretty good.
SJConsultant said:We have GFI MailEssentials installed at a couple customer sites but it never seemed to work as well as it should even with people contributing to the "spam" and "not spam" folders. We will be converting them once the maintenance contract is up to ORF so long as we don't run into any major issues.
mike2323 said:ORF doesn't look like it can do global disclaimers. I need something that can also add that on to emails. I was thinking GFI. Any other recommendations?
mike2323 said:Thanks for the link. I didn't see anyone else post that. I think I will check out ORF afterall.
swatbat said:I haven't tried this but it might be something to look into.
This will only work if you are using either a "Front-End" Exchange server or if you are using a SMTP smart host. Without a smart host it will not work in sbs(not sure if this is an issue for you)
I've installed this over the weekend onto my own office Exchange Server, and have to say it's pretty impressive so far. I put it on to evaluate for a few clients, and it appears to be extremely effective. And yeah- the Graylisting and Tar pit are awesome- almost none of them re-send after the delay, effectively making them disappear. Sweet.SJConsultant said:I have installed trial version of Vamsoft's ORF on two Exchange Servers so far.
jefe said:I have gone through their site and the help on the program, but I find both to be quite lacking. Anyone have more luck than I?
