I have a macro written in VB that works but not "perfectly".
Basically it looks at a range of cells and replaces X text with Y text. Very simple.
The problem that I have is I would like for it to replace the text with a literal match.
For example:
Replacing "B" with "BOMB" on a row that has "BOMB" on it would result is "BOMBOMBOMB"
What happens is it takes every "B" and replaces it with "BOMB".
What I would like it to do is to replace cells that have literally only "B" in them with "BOMB".
If a cell has anything else than just "B" it is ignored.
Here is the code:
For example:
Here is the code:
Code:
Sub Replace_ALL()
Dim lr As Long, c As Integer, r As Integer
With Application
.Calculation = xlCalculationManual
.ScreenUpdating = False
.DisplayAlerts = False
.EnableEvents = False
End With
lr = Cells(Rows.Count, "A").End(xlUp).Row
For r = 1 To lr 'cycle rows
For c = 1 To 1 'columns A to A
Cells(r, c).Value = replace(Cells(r, c).Value, "B", "BOMB")
Next c
Next r
With Application
.Calculation = xlCalculationAutomatic
.ScreenUpdating = True
.DisplayAlerts = True
.EnableEvents = True
End With
End Sub
