Hello
Part of my job is to take readings of a car instrument panel and see where the color and luminace are according the the CIE chromoaticity chart. We are using software that is quite old and the only option for data exporting is copy/paste. This is an example of the raw data:
What I do is take that data and manually enter it into an excel template that cleans it up and looks more presentable. The down side to this is I am prone to typo's and it is very tedious. The format I put it in is like this:
Each location is a new row in excel and follow the colum format. I am wondering if anyone could help me manipulate the data thats in the clipboard with a vba macro or code. The data is always in the same format so I'm thinking a loop would work well. I know some vba but am very rusty.
Thanks!
Code:
Obs: 2 deg. Sw801 Sw802 Sw803 Units
Luminance 8.389e+000 8.795e+000 2.457e+001 cd/m2
2.449e+000 2.567e+000 7.171e+000 fl
x 0.1811 0.1901 0.1981
y 0.3898 0.3913 0.4038
u' 0.0990 0.1040 0.1064
v' 0.4795 0.4814 0.4878
Code:
Location x y u' v' cdm2 fl
Sw801 .1811 .3898 .0990 .4795 8.839 2.449
Thanks!
