Excel question - simple?
Discussion in 'General Software' started by KevySaysBeNice, Dec 13, 2007.
  1. KevySaysBeNice
    KevySaysBeNice [H]ard|Gawd
    1,452
    Dec 7, 2001
    Hi, I have two questions, hardest question first:
    I want to order documents in Excel based on how many times the element shows up in a column. For instance, here is a simple example:
    Column A
    1
    1
    1
    2
    3
    3
    I'd like to sort that column so that 2 is first (because there is only one 2), three is second (two 3s), and 1 is last (three 1s!).
    Is there a way to do this?
    Second question:
    If I have an excel sheet with a bunch of blank rows, is there a way to automatically remove all of the blank rows and condense everything?
    Thanks in advance for any help :heart:
  2. k1pp3r
    k1pp3r [H]ardness Supreme
    7,744
    Jun 16, 2004
    Personally i would sort the column in accending order, then in say column C use the COUNT function to tell you how many 2's there are and how many 3's and so fourth
  3. Druneau
    Druneau [H]ard|Gawd
    1,747
    Jan 3, 2006
    Kind of expanding on k1pp3r's suggestion...
    Make a table with the possible values your data can be. Have a column beside it which will use "=COUNTIF(E4:E38,A5)" to count how many of a certain value. Then you can run a standard sort on the "count" column to sort your value column accordingly.
  4. Druneau
    Druneau [H]ard|Gawd
    1,747
    Jan 3, 2006
  5. KevySaysBeNice
    1,452
    Dec 7, 2001
    well, that's true, but i don't think that's really possible with 1,500 rows.
    What I'm trying to do, basically, is take a bunch of data and eliminate every row where column A (actually a "Purchase Order") shows up only once. The rows where it shows up more than once can stay.
  6. Druneau
    Druneau [H]ard|Gawd
    1,747
    Jan 3, 2006
    ok....
    Then have =IF(COUNTIF($C$7:$C$40,C7)>1,C7,"") formula as a column.
    This will get you the purchase order name only if it's found more than once in the data. If not, then you get a blank cell which you could remove using the method in the link i've provided. (I'm sure we could find a better way of removing those blank cells...)
