Jan 8, 2006 #1 D Duster Supreme [H]ardness Joined May 4, 2002 Messages 5,838 Ok I was wondering is there a way to sort an entire column while sorting other columns with it... I.E. I have column A that I want in ABC order but columns B and C that go with A so I want those sorted along with A Kind of like Before Code: c 7 b b 1 a a 9 c After Sorted Code: a 9 c b 1 a c 7 b
Jan 8, 2006 #2 Oldie Mean Old Administrator Staff member Joined Jan 12, 2004 Messages 21,888 If you just select the entire area you want to sort, just click on Data | Sort and set your criteria. The default behavior is to sort all fields, unless you make a different selection.
Jan 9, 2006 #3 D Duster Supreme [H]ardness Joined May 4, 2002 Messages 5,838 thanks yeah i figured it out... i was being dumb for some reason
