Blade-Runner
- Feb 25, 2013
I have had the Hybrid installed in my case for about a week and the entire time it has been emitting very loud water sloshing/bubbling noises at startup which quieten after about 5 minutes, but it then intermittently makes other noticeable noises which sound very much like running water. The startup noise is similar to what is captured in this video:
https://www.youtube.com/watch?v=XZF3OfvXwq4
Changing the orientation of the reservoir and tubing did not fix the problem, and neither has shaking the reservoir or allowing the GPU to run for extended periods. I have already emailed EVGA support who have suggested returning or RMA'ing it.
I didn't expect the Hybrid to be completely silent, but relative to the Corsair H100 installed in the same case, these noises are excessively loud and distracting.
In deciding whether to get a refund or replacement, can other owners tell me whether they have experienced similar problems? I haven't found too many complaints of this across other forums, so I am hoping that a replacement will not exhibit the same problem.
