I just installed a EVGA GTX560Ti 2GB card in my new PC (ASUS P8Z68 Deluxe GEN3, i7-2600K, Win 7 64 bit) along with the latest 285.62 driver.
It's connected to a Sharp 1920x1080 HDTV via HDMI.
At card settings of 1920x1080p the desktop is larger than the screen area. It overlaps so that only the very top edge of the taskbar is viewable, and the icons on the left and right edges of the screen are 2/3 hidden off of the sides of the screen.
To get the desktop to fit I had to change the resolution manually to 1824x1026.
Now the desktop fits but it is a tad blurry.
How do I get the 1920x1080 settings to match my monitor?
My former graphics card, an EVGA 8800GTS worked perfectly at this resolution.
Thanks.
Thanks.
