Armenius
Extremely [H]
- Jan 28, 2014
Saw this come across in my e-mail. Early availability begins April 8 exclusively for Associate members. I'm pretty sure this will be the first K|NGP|N that is cooled by an AIO.
I wonder how much the cost would be.. I am guessing probably around $1799... sigh.. As much as I would love to own this little monster.. a little too high out of my price range heh
Agreed. I like these cards but the mark-up in price is usually pretty huge for the small performance bump.
My problem with these cards is they come out so far into the cycle... and for practically no advantage compared to watercooling and modding months and months earlier.
Exactly. If you bought this and used it to play games, you're doing it wrong. That would be like buying a homologation special car to drive to work and the grocery store.AFAIK they exist only so that plebs can have their own chance at beating Kingpin in the leaderboards- and EVGA (his employer) can make a buck off the effort.
[and there's not a damn thing wrong with that]
If the mention over at TPU is accurate, ~$1900I wonder how much the cost would be.. I am guessing probably around $1799... sigh.. As much as I would love to own this little monster.. a little too high out of my price range heh
Why EVGA opted to not ship their Hybrid series with a 240mm radiator as a default option I'll never understand.
uh no, actually that would be more of a dyno run as that's more equivalent to benching on a computer, in car mechanic speak. playing games would be equivalent of using the hella expensive performance car you bought brand new with, to race with. if buying just to browse websites or and do work with, that would be equivalent to "drive to work and the grocery store."Exactly. If you bought this and used it to play games, you're doing it wrong. That would be like buying a homologation special car to drive to work and the grocery store.
What you're supposed to do with this is competitive overclocking.
I honestly think that cannot be possible, my 480 rad gets real hot to touch when my CPU is 100% utilized, and this 300W graphics card, is more than double my CPU TDP, will survive on a thin 120mm rad?! Pffft please.....you would need maybe two thick 480 rads minimum to cool this monster quietly....3 if you wanna include the cpu in the loop so it's not two separate custom loops...4 or more of these thick 480 rads (or just use a car rad lol) would probably be better, that way you can try for a passive cool n or less fans = less noise.It's not needed. Really.
A single 120mm AIO with a single fan can handle the heat output of a top-end GPU, quietly.
[the disparity with CPUs isn't something I've thought about enough to try to explain, but I do recognize that lower-wattage CPUs make use of more cooling capacity]
How effectively that heat is dissipated is equally as important as knowing total heat output. The power delivery, die size, chip surface area matter a lot. The 2080 Ti is like 4x bigger than a Coffee Lake CPU. My 9900K frequently touches 80C with a 360mm radiator while my 2080 Ti rarely touches 60C with a 120mm radiator (most of its time is spent in the low 50s).I honestly think that cannot be possible, my 480 rad gets real hot to touch when my CPU is 100% utilized, and this 300W graphics card, is more than double my CPU TDP, will survive on a thin 120mm rad?! Pffft please.....you would need maybe two thick 480 rads minimum to cool this monster quietly....3 if you wanna include the cpu in the loop so it's not two separate custom loops...4 or more of these thick 480 rads (or just use a car rad lol) would probably be better, that way you can try for a passive cool n or less fans = less noise.
Then the fans on your rad aren’t spinning fast or have no static pressure. Or your pump isn’t circulating fast, or your rad is gunked up inside.I honestly think that cannot be possible, my 480 rad gets real hot to touch when my CPU is 100% utilized, and this 300W graphics card, is more than double my CPU TDP, will survive on a thin 120mm rad?! Pffft please.....you would need maybe two thick 480 rads minimum to cool this monster quietly....3 if you wanna include the cpu in the loop so it's not two separate custom loops...4 or more of these thick 480 rads (or just use a car rad lol) would probably be better, that way you can try for a passive cool n or less fans = less noise.
