EVGA SSC 2.0+ @ Newegg for $315 after rebate.
Use Promo Code: EMCASAW76
SSC 2.0+ is the exact same thing as the FTW+ cept no backplate and lower clocks.
Improvements over the first models include: http://hexus.net/tech/news/graphics/78613-evga-launching-new-improved-geforce-gtx-970-ssc-card/
- Batman: Arkham Knight (Steam Voucher)
- Witcher 3: Wild Hunt (GOG Voucher)
- EVGA GTX 970 SSC Backplate (100-BP-3973-B9)
The new generation of EVGA GeForce GTX 970s have arrived with the FTW+. This enhanced model offers an included backplate, improved cooling, double BIOS support, new display output configuration and 6 power phases for robust overclocking support.
The new EVGA ACX 2.0+ cooler brings new features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET and Memory temperatures and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimized Swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
New Features:
Backplate - Included backplate gives the FTW+ card a nice clean look, and helps reinforce the PCB.
dBi – dB Noise Inverter turns fans off below 60C, generating 0dB of noise during idle!
QSD BIOS – Quick Switch Dual BIOS allow you to switch to secondary BIOS with the flick of a switch.
MMCP – Memory MOSFET Cooling Plate reduces MOSFET temps by 47% and Memory by 14%.
OPT – Optimized Power Target offers 33% more power over reference.
SHP – Straight Heat Pipes reduce GPU temperature by almost 5C!
