psy81
- Feb 18, 2011
Just curious what kind of fan profile you guys are using on your cards and any tips.
My fan profile is as follows:
I just kind of made it up and as I went along. Does this look okay or off to you guys? Also, is it okay to keep the fans off between 0-47 degrees in long run or should i keep the fans running? Any tips would be much appreciated.
Thanks!
- 0 - 47 Degrees Celcius: 0%
- 50 Degrees: 30%
- 60 Degrees: 55%
- 70 Degrees: 70%
- 80 Degrees: 85%
- 90 Degrees: 95%
- 100 Degrees: 100%
Thanks!
