EVGA 980 ti Hydro Copper question
Jeff G
Does anyone know if this card has a LED lit block? I tried "googling" pictures of it, and it appears as though it does. Mine does not light up though. Just curious if something is wrong with the LED on mine or if they dont actually light up.
Jeff G
My phone doesnt seem to work for uploading photos, but the linked photo is what I'm looking at. Not the small logo on the inlet/outlets, but the actual block that seems to be lit up.
doubletake
It could be something wrong with the LED, or it might just be disabled atm. You can try to control with the nVidia LED Visualizer or with EVGA Precision. If it won't turn on using either of those, then it's most likely dead.
Jeff G
So, it should have a LED you think? I haven't tried either of those, but will tonight. Didnt want to start messing around trying to get something working that wasnt there in the first place lol.
doubletake
If it is specifically the one you linked a picture of, the "GAMING" variant that has an acetal faceplate with the EVGA logo cut out, then yes, it's supposed to be LED-lit.
Jeff G
This is the actual card in my system:
I tried both the LED Visualizer and XOC, neither worked for any LEDs. I'm guessing either the LEDs are bad or unplugged. I just finished the loop so I'll probably not worry about it until the next time I tear it down. Thanks though!
