EVGA 980 TI FTW w/Backplate - $609.99 (after $ 20 MIR)
Discussion in '[H]ot|DEALS' started by Humpernator, Mar 22, 2016.
  1. Humpernator
    Humpernator [H]Lite
    112
    Oct 23, 2015
  2. ravx25
    ravx25 [H]ard|Gawd
    1,525
    Apr 2, 2005
    Are these really worth investing into at this point with Pascal around the corner?
    DF-1 likes this.
  3. Slava
    Slava 2[H]4U
    2,316
    Mar 20, 2002
    I got this one and love it. You can step up upgrade within 90 days of purchase :D
  4. Trepidati0n
    Trepidati0n [H]ardForum Junkie
    8,854
    Oct 26, 2004
    Investing is a interesting choice of word.
  5. darrpara
    darrpara Gawd
    678
    Apr 26, 2011
    Is the step up program worthwhile? Who knows if Pascal will even be out at all in 90 days.
  6. dr.stevil
    dr.stevil [H]ardForum Junkie
    9,093
    Sep 26, 2008
    lol can you step down?
    I purchased a classified 980ti from the deal last week and I didn't realize how huge the PCB actually was on it. If I can't find a solution for the PCI-E connectors that'll work with my case, I'll need a ti with a shorter board
  7. darrpara
    darrpara Gawd
    678
    Apr 26, 2011
    Even with those shortened connectors from the other thread? Wow that is tight spacing then.
  8. dr.stevil
    9,093
    Sep 26, 2008
    lol this is what I have to work with
    I ordered two of those cut down low profile connectors but I'm skeptical it'll work. Keeping my fingers crossed but have a feeling I need another GPU for this build. As an added downfall of the GPU height, it separates the case in two which means I can't mount my radiator near the PSU anymore. Idle temps are noticeably warmer (approx 10*)
  9. darrpara
    darrpara Gawd
    678
    Apr 26, 2011
    Wow that really is a tight fit. Good luck with the connectors I think they might work for you.
  10. damstr
    damstr [H]ard|Gawd
    1,362
    Jun 26, 2005
    Nothing is an investment when it comes to computers. I know what you meant though and no definitely not. I am needing an upgrade and with Pascal right around the corner I will either pick up a newer Pascal card, or grab a 980 Ti for around $500 or so maybe even cheaper depending on what Pascal launches at.
