eVGA 6800nu + 350w Enermax = ???
Mojo
Will my 350w Enermax be able to handle it. My other specs are in my sig. Basically, an A64 3000+, 1024mb ram, 80gb hd, 2 x 120mm fans, etc. I was thinking of possibly adding raptors later, that would not be possible if I had this setup plus a 6800, would it?
It should be able to, I don't know if I'd go and add a bunch of other HDD's especially raptors, but for now the enermax should be fine.
Absolutely...I saw a review of an Ultra where they did all of the testing off of a Antec 300w. It's all about the quality of the power supply.
And Enermax/Antec are the best, correct?
Do you think I could pull off having two raptors in raid 0 too in the future?
i have an antec trueblue 350w , a gainward superfanpowered 6800NU, a raptor, gig of memory, etc etc and it runs fine
Don't worry about it. I'm using a $5AR special 350W A+GPB PSU from Fry's with a lot more hardware than that. See my sig.
<3 A+GPB PSUs. IMO, those are the best low cost PSUs available.
