every pascal card i have owned has noticeable coil whine
Discussion in 'nVidia Flavor' started by dchobaby, Jan 18, 2017.
  1. Comixbooks
    Comixbooks Ignore Me
    10,450
    Jun 7, 2008
  2. HoffY
    HoffY Gawd
    900
    Mar 7, 2005
    ummm. no. Like i explained, i've diagnosied those kinds of things out of the equation. Its directly related to loads on GPUs or CPUs.
    Nup. hearing like a 20 year old. You jealous bro? :p (you should be)!
    Yep that is one way to describe one of the times i heard the sound. The on in my system now isn't so much high pitched however. can be likened to the noice a HDD head makes of the olden days. But much more quiet and finer grained and not so much high pitched. But very much relatable to constant CPU load/ativity. Its weird a.f! lol
    yup all of that indeed. thanks. It was late. i was fried. :p
    Thanks for the info. great idea. i did try that on other systems i've heard similar sounds on and it didnt give any indications but i'll have to try it on this system and see how that goes. its only happened on this system since i moved house a month ago. Either that or the different room acoustics has made it direct the sound so its more easily heard or something possibly.
    Its generally not a big issue but i was very much intrigued to see if this could be it as i suspected something like this could be the cause. If its not quiet you never hear it of course. (like if on YouTube or watching a movie/tv).
    i don't have the former but i'll take the latter ;)
    Spartacus likes this.
  3. DWolvin
    DWolvin [H]ard|Gawd
    1,774
    Nov 13, 2002
    I know it sounds crazy HoffY, but it might be another component. I have an SSD (1 of 3) that is audible when reading or writing. I have a sound damped case (Fractal Define XL) that muffles it when the sides are on, but if I have the side off I can hear that particular drive. I thought I was crazy, but it's confirmed by others... Any power circuit could be doing it is what I'm saying...
    kalston and Armenius like this.
  4. Iratus
    Iratus [H]ard|Gawd
    1,040
    Jan 16, 2003
    Bit iof a necro but I've got the same thing on my 1080Ti FE, I never noticed because my sides were off as I tried to lock in my OC.
    I'm on full water so it must be the phase control on the GPU, it's directly linked to load. If I do the tesselation burner test on MSI I can really hear it, a few of the other stres tests make it audible.
    That's even at stock settings. Don't really care but it is bizzare.
  5. Lmah2x
    Lmah2x Gawd
    536
    Apr 3, 2014
    I haven't had coil whine since my GTX 680s. Maybe I'm just lucky.
  6. vegeta535
    vegeta535 [H]ard|Gawd
    1,662
    Jul 19, 2013
    I don't understand how sensitive you people are. I have coil on my 1080 and can only hear it if I go looking for it and put my ear near my tower. My hearing is not the greatest but damn people.
    Armenius likes this.
  7. Armenius
    Armenius [H]ardForum Junkie
    12,944
    Jan 28, 2014
    The loudest thing in my PC now is the whirring of my fans, and I can't hear them unless I put my ear right up to my case.
    Shintai and vegeta535 like this.
  8. vegeta535
    1,662
    Jul 19, 2013
    Yep.
  9. Nenu
    Nenu Pick your own.....you deserve it.
    17,776
    Apr 28, 2007
    I've heard serious coil whine and it can piss you off.
    Depends how bad it is and the situ it is in.
    I've only had cards with mild whine, my 1080ti is pretty quiet and 3 metres away so all good.
  10. Stoly
    Stoly [H]ardness Supreme
    5,560
    Jul 26, 2005
    The only card I've owned that had coil whine was a GTX 650 and it dissapeared after a driver update.
    I have a GTX1070 and GTX1070Ti and no coil whine on different pcs.
  11. kalston
    kalston Gawd
    962
    Mar 10, 2011
    I can't remember the last time I've had a GPU that I can't get to produce coil whine, if I want to make it happen. However in actual usage it's never been a problem for me. Ever since 2014 I'd had a g-sync monitor so I haven't heard the high framerate whine in a long time for example. But if I disable g-sync yes, I can make it happen in a few game menus.
    There are a few instances where my 1080 ti will make a very faint coil whine (as in - when I bring people over they can never hear it and if there's any sound coming out of my speakers/headphones I can't hear it either), but it's limited to a handful of applications really. I haven't tried swapping PSU, rocking the same one since 2012, because it's working well after all so why bother.
  12. Armenius
    12,944
    Jan 28, 2014
    Now that I think about it, I did get coil whine out of my GTX 970s when I ran Furmark for about 30 seconds.
  13. kimura14
    kimura14 n00bie
    25
    Dec 17, 2016
    I have tinnitus and get ringing with migraines, and notice coil whine very differently than both. I get a little whine from my cpu running hard on a x99 board, but it is nothing compared to the whine from my titan xp when it's running. Both on water so it's very noticeable. I also have a titan v that I can't hear but then again when I get it going I set it up to 95% fan speed. Linus tech tips says his v was whiney but I will need a water block to notice it vs the fan. Not positive it's related but I'm someone who can't be near an induction grill because it's so loud, and that's a similar sound imo.
  14. pendragon1
    pendragon1 [H]ardForum Junkie
    8,480
    Oct 7, 2000
    limiting your fps to that of your display will greatly reduce coil whine...
  15. bal3wolf
    bal3wolf Limp Gawd
    259
    May 14, 2008
    Yea i get migrains to or used to mine are better but i had to replace all my fans in my case because they drove me nuts and made my head hurt worse people that dont experince dont have any idea how much pain it can cause.
  16. Iratus
    Iratus [H]ard|Gawd
    1,040
    Jan 16, 2003
    Good to know, I've got a high refresh monitor so it's not like it will cause a problem.
    In fairness it's only really when I was tuning everything in that I noticed it, if it wasn't on water it wouldn't be noticeable but I've got a dual 360's and my fans are at like 4.2v 95% of the time so it's pretty quiet. As a rule the noise from my Vive lighthouses is WAY more annoying, they often decide they don't want to sleep.
  17. JRUHg
    JRUHg Limp Gawd
    370
    Jan 5, 2016
    i can remove the pain of GTX for 100 dollars!
