every pascal card i have owned has noticeable coil whine
Discussion in 'nVidia Flavor' started by dchobaby, Jan 18, 2017.
  1. dchobaby
    dchobaby [H]Lite
    71
    Aug 16, 2016
    I've gone through 4 TXP's, 2 1080 FE's, a 1070 IN A GDAMN NOTEBOOK, and now the 1080 Hybrid.
    THEY ALL HAVE COIL WHINE. WHAT THE HELL NVIDIA.
    k that's it.
  2. mnewxcv
    mnewxcv [H]ardness Supreme
    6,186
    Mar 4, 2007
    I havent had a PC without some form of coil whine in years. I gave up on a truly silent PC because of it, and decided I'd rather hear a fan slowly turning than silence other than whine.
    dchobaby likes this.
  3. dchobaby
    dchobaby [H]Lite
    71
    Aug 16, 2016
    it does seem like a futile effort.. but man. my 290x's were dead silent.. that is of course until they hard locked my system without warning and sent a shrieking sound through the speakers.
  4. jeremyshaw
    jeremyshaw [H]ardForum Junkie
    12,058
    Aug 26, 2009
    My SFF build's 1050Ti is dead silent. I replaced the old PSU, since it had serious whine at idle. Add in a better case fan, and I now have an absolutely silent desktop under my desk. I sleep less than 10 feet away, and it is absolutely inaudible (a first for me).
    Either my ITX or MATX computer will become my Ryzen host, price/perf pending.
    After 2 years, now my laptop had started making weird noises o.0.
  5. ElBerryKM13
    ElBerryKM13 [H]Lite
    117
    Apr 3, 2015
    Maybe there is something wrong with you. Maybe ear infection?
  6. jeremyshaw
    12,058
    Aug 26, 2009
    I like your common cause theory, but I doubt it is OP's body. Probably PSU/Mobo + seriously bad luck with the laptop.
  7. Comixbooks
    Comixbooks Ignore Me
    11,992
    Jun 7, 2008
    Nvidia doesn't make the Fans
  8. cdabc123
    cdabc123 2[H]4U
    2,125
    Jun 21, 2016
    i got around 20 amd cards and not a single one makes a peep (excluding fan noise) i have about 5 nvidia cards and 2 have coil whine :( I NEED THE 490 ALREADY!!!
    N4CR and dchobaby like this.
  9. thesmokingman
    thesmokingman [H]ardness Supreme
    4,837
    Nov 22, 2008
    My TXP only whines when it's hitting over 1000fps. On anand there was this thread to run 3dmark06 and holy carp the fps was hitting 2k fps.
    bjornb17 likes this.
  10. Nenu
    Nenu [H]ardened
    18,270
    Apr 28, 2007
    Fan coils arent noisy tho...
    Brian_B likes this.
  11. TrailRunner
    TrailRunner Limp Gawd
    349
    Feb 15, 2012
    No coil whine that I can hear in my 1080 FTW. Beyond that, the card is totally silent at the desktop, the fans don't even spin.
  12. Shintai
    Shintai [H]ardness Supreme
    5,717
    Jul 1, 2016
    No coil whine from either my old 680, 980 or my current 1080. I think the last coil whine I had was on an Intel DH57JG board for HTPC when using USB in certain ways. Have you isolated the whine to the cards and not from somewhere else?
    If you got so much coil whine on so many different cards I would check PSU/External power quality. Even for the Fiji coil masters, you find a card after 2-3-4 attempts without whine.
  13. arestavo
    arestavo [H]ard|Gawd
    1,409
    Mar 25, 2013
    I would hazard a guess that the power supply has poor DC ripple supression, or if it originally had good ripple suppression it has since degraded.
    Some cards will have could whine, but like the dude who "literally had 12 1080s from 5 different manufacturers" that had coil whine, a really good place to look next would be power delivery (PSU, Active PFC compatible UPS, etc.).
    Dayaks, Bandalo, Algrim and 2 others like this.
  14. lostin3d
    lostin3d [H]ard|Gawd
    1,639
    Oct 13, 2016
    I agree wholeheartedly. It could just be my case having so many fan's, but I don't hear anything from my 2 Xtreme 1080's. For almost as many stories there are about coil whine there's a near equal amount about poor PSU/MOBO issues. On some occasions I've done tests and had the desktop literally on the desktop next to the monitor and still only heard the light sounds of fans. I don't know the db for my system but its usually reminiscent of having a small desk fan on low.
    Even though the Corsairs I use haven't gotten the best of reviews for their tiers(80+ gold/platinum), I've never had an issue. The 1200w I use for the 1080 system is now pushing 4 years and more hours than I can keep track of. It used to power my 2xG1 OC970's and a SC780 along with 5 or 6 hdd's. I also usually have my systems plugged into 1000w+ APC UPS. They too may not always be at the top of the tier but clean stable power to the PSU probably helps also.
    I always make sure to use all the plugs 6/8 8/8 etc. Regardless of what the number crunching specs say, I believe in giving the cards all the potential they can to do their job.
  15. Armenius
    Armenius [H]ardForum Junkie
    15,449
    Jan 28, 2014
    In 17 years of owning NVIDIA cards I have never had one produce any coil whine.
    (Hercules GeForce2 MX, BFG GeForce4 MX 420, BFG FX 5900XT, BFG 7800 GS AGP, BFG 8800GTX OC2, EVGA GTX 570 HD 2.5GB, EVGA GTX 780 SC, ASUS GTX 970 STRIX, EVGA GTX Titan X SC, NVIDIA Titan X)
    But I always buy quality power supplies.
    dchobaby and Geforcepat like this.
  16. Algrim
    Algrim [H]ard|Gawd
    1,280
    Jun 1, 2016
    I've never noticed coil whine in any video card I've had (3dfx, ATI, nVidia). Maybe I've just been lucky or maybe the voices inside my head are louder than any coil whine. :oldman:
    arestavo, jeremyshaw and Armenius like this.
  17. Napoleon
    Napoleon Gawd
    997
    Jan 27, 2003
    Maybe put on some music or play video games with sound...
    Florin22xxl and Geforcepat like this.
  18. buttons
    buttons [H]ard|Gawd
    1,998
    Oct 12, 2011
    I have 17 AMDs , three old nvidias. The only one of the twenty that whines is a gigabyte 7970 ghz under load. I have two of these gigabytes, only one whines-- i chalked it up to eminent failure but here it is 8 months later still mining
  19. dchobaby
    dchobaby [H]Lite
    71
    Aug 16, 2016
    I've had good power supplies paired with these cards as well (AX1500i, EVGA P2, Seasonic Platinum). Maybe I have terrible luck.
  20. DWolvin
    DWolvin [H]ard|Gawd
    1,865
    Nov 13, 2002
    My last- OG 7970 had coil whine under load until I put a full cover water block on it, but I have to admit that i don't know if it was blocked by the cover, or if the whine was silenced by the improved cooling. My current 1080 came with an aftermarket (EK?) waterblock and never whines, even if overclocked to artifacting.
  21. Dayaks
    Dayaks [H]ardness Supreme
    6,369
    Feb 22, 2012
    How do you know it was the 1070 in the notebook?
    PSUs, especially on notebooks often have coil whine. You might not hear it until it gets loaded either.
  22. Rizen
    Rizen [H]ardForum Junkie
    9,185
    Jul 16, 2000
    Weird. My Titan XP is silent.
  23. Shantarr
    Shantarr Limp Gawd
    207
    Mar 28, 2016
    I've heard coil whine once, ever. Could be some people are much more sensitive than others and at that point, it's not the companies fault to build to outliers.
    Brian_B likes this.
  24. Nenu
    Nenu [H]ardened
    18,270
    Apr 28, 2007
    Well balanced conclusion.
    You didnt even make your statement without error.
  25. bal3wolf
    bal3wolf Limp Gawd
    261
    May 14, 2008
    both my 7970s right now have coil whine and alot of it as they aged they have got worse can hear them over my fans all 15 fans im making the switch to a 1080 hydro copper so i hope its pretty quiet lol.
  26. Shantarr
    Shantarr Limp Gawd
    207
    Mar 28, 2016
    Yeah I see it, I'll leave it as to not bury my shame.
  27. Supercharged_Z06
    Supercharged_Z06 2[H]4U
    2,361
    Nov 13, 2006
    Gone through lots of video cards as a PC hobbyist. Most coil whine that I've encountered can be drastically reduced and sometimes even completely eliminated by switching out and applying a high-quality, top rated power supply that has plenty of reserve - i.e. one that isn't being pushed anywhere near its rated limit.
  28. bal3wolf
    bal3wolf Limp Gawd
    261
    May 14, 2008
    sadly sometimes they just get louder as they age like both my 7970s didnt whine at all till about the last month and they are really loud now even at low fps.
  29. Ieldra
    Ieldra I Promise to RTFM
    3,597
    Mar 28, 2016
    I dislike coil whine as much as the next guy, but serious it's just a question of damping the vibrations. Coil whine is unavoidable and afaik the most effective solution is to use inductor whose geometry minimizes the vibration, I'm pretty certain the design of the gpu has no bearing whatsoever, so speak to asus, msi, etc cause they make the boards and they're in charge of the glue
  30. waderunner
    waderunner Gawd
    907
    Jun 2, 2013
    I've had 3 different GTX 1060 6GB models. They have all have been free of coil whine. Also a 1050 ti that's quiet. That's one reason I like going with a mid-tier card rather than higher end (like the 960 vs 970; 970's had bad coil whine issues, 960's didn't seem to...
  31. KickAssCop
    KickAssCop [H]ardness Supreme
    6,512
    Mar 19, 2003
    Tried ASUS STRIX?
    Also what PSU?
    Which situations cause the whine?
  32. RAutrey
    RAutrey [H]ard|Gawd
    1,584
    Jul 25, 2002
    My son's Zotac 1070 doesn't. I'm really more an AMD guy when they can compete but I have to admit; The 1070 is a great card.
  33. geforce man
    geforce man [H]ard|Gawd
    1,085
    Jan 18, 2006
    I thought I was having an issues with cards and coil whine. Turns out it was the PSU. Changed it out, and coil whine is magically gone! :)
  34. [Paragon]
    [Paragon] Gawd
    696
    Dec 28, 2005
    Had coil whine with my 390 on a corsair hx650, replaced with a rm 850i and the whine went away. Replaced the 390 with my 1080 and haven't heard a thing, card is so quiet and cool even under load.
  35. HoffY
    HoffY Gawd
    936
    Mar 7, 2005
    forgive my ignorance.
    could somebody define this "coil whine" ?
    i've had a few computers over the years exhibit a weird "squeek" ritchety noise (very difficult to put into words but it seems like a noice a CPU would make when it "thinks" lol) when you do something and its quiet (like move the mouse) and i dont know wtf causes it. I've hd it happen when id o graphics intensive things and any small tests i did pointed to it being the GPU (8800 GTX at one point, a quado another time).
    i feel perhaps it may be what is being spoken about here. :)
  36. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    51,388
    May 18, 1997
    Maybe you have tinnitus?
    Aluminum and Armenius like this.
  37. Armenius
    15,449
    Jan 28, 2014
    The squeak is probably from a bad fan bearing somewhere in your system. Coil whine is an extremely high-pitched audible whine. There is no better way to describe it. I'm sure you could find a video somewhere that caught it on a recording.
    Ieldra likes this.
  38. thesmokingman
    4,837
    Nov 22, 2008
    Adding to that, it's a mechanical whine that is load induced. Basically power regulation components vibrate more than usual. It also has a rapid paced ticking sound quality to it.
    Armenius likes this.
  39. Ieldra
    3,597
    Mar 28, 2016
    To be clear I've seen tons of people making posts like these, your previous PSU was very likely NOT FAULTY. It was just fine, it's just coincidence that that PSU with that card just happened to lead to resonance which increases amplitude of vibrations.
    spine and [Paragon] like this.
  40. Spartacus
    Spartacus [H]ard|Gawd
    1,898
    Apr 29, 2005
    Try turning off your computer audio and see if you still hear it.
    You can get high frequency noise that leaks into the mobo audio.
    On some systems, I've also had the issue of moving the mouse and hearing for lack of a better term, "interrupt noise".
    Maybe the movement of the mouse causes more interrupts and changes bus traffic and thus the noise leaking into the audio.
    I agree that's possible. And I also want to point out that "tinnitus" has the letters necessary to spell "tits".
    Kyle_Bennett likes this.
