Good afternoon,
First of all I must specified at the beginning that I am a beginner in mining.
Second, I have an rig made using ASUS Z270-P as motherboard, 16 GB RAM memory, as operating system I use ethOS, and as GPU I use 4 NVidia from Gigabyte (model 1060 - 6Gb). I use wallet made/create on MyEtherWallet and I mine Ethereum Classic (ETC). As pool I use nanopool.org.
In the next picture I attached the performance of my GPU's:
For this "performance" I don't change nothing on my default settings. But I want to change the GPU's performance only undervolt and overclock GPU's without using BIOS modded. So, the settings use for mine are:
# -----My NANOPOOL Settings - ETC -----
# globalminer etcminer
maxgputemp 85
stratumproxy enabled
proxywallet <my_wallet_ID>
proxypool1 etc-eu1.nanopool.org:19999
proxypool2 etc-eu1.nanopool.org:19999
# poolpass1 x
# poolpass2 x
poolemail <my_e-mail>
flags --cl-global-work 8192 --farm-recheck 200
# globalcore 1000
# globalmem 1250
globalfan 85
# globalpowertune 20
# autoreboot false
# custompanel publicsecret
# lockscreen enabled
# globaldesktop disabled
# globalname disabled
How I can change the settings in a way in which to increase the GPU's performance ? Also what command I must use (in terminal) to see the GPU's performance when mine ?
If somebody from community already have this type of GPU and already have it optimized only with this settings what values/characteristics use ?
I waiting your feedback with very higher interest your opinion/suggestions/advice !
Thank you in advance to all community for support.
Keep in touch !
maxgputemp 85
# poolpass1 x
# poolpass2 x
# globalcore 1000
# globalmem 1250
globalfan 85
# autoreboot false
Keep in touch !
