Bullitt
- Sep 28, 2004
Has anyone tried this? My only experience was accidental when trying to make a amd64 port work on my rig. The debian installer at the time, would pick up on the firewire interface and attempt to run tcp/ip over ieee1394.
Long story short, I want to play around with it b/c my fileserver is physically close and I dont have a gig-e interface in that box.
I've been googling most of the night for a howto or something to get the bloody thing working, but I'm banging my head against the wall.
lspci shows the device there (a Texas Instruments device, supposedly well supported by the eth1394 module).
modprobe 1394 goes well, but doesnt assign an "ethx" interface for me to play with.
rmmod eth194 and a manual "insmod eth1394 eth1" yields "eth1394: disagrees about version of symbol struct_module"
gscanbus result "couldn't set port: Invalid argument"
The last thing I read was that eth1394 support has to be built into the kernel instead of a loaded module. I'm re-compiling a kernel and forced eth1394 to be built-in (not a module) but am I on the right track?
Edit: I was using a stock debian 2.6.11 kernel, then 2.6.14 before I started a recompile.
Code:
0000:00:0d.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link) (prog-if 10 [OHCI])
Code:
lsmod | grep 1394
eth1394 19208 0
raw1394 27884 0
ieee1394 92856 2 eth1394,raw1394
