With Ethereum finally shifting to PoS in a few months, what will you mine?
If I missed your choice -- put it in comments and I'll add it.
So wait Raven doesn't mine with the memory?Raven is on the next list but holy hell, mining back with the gpu core is brutal for heat and power. Back to the giant box fan to keep temps reasonable it seems if I can manage in West Texas heat.
I'm wondering this as well. I didn't notice any difference in temperatures going from eth to rvnSo wait Raven doesn't mine with the memory?
I will have to double check, I thought it was RVN that also used the gpu core.I'm wondering this as well. I didn't notice any difference in temperatures going from eth to rvn
Could be. I am running the cards in a rack, so I'm sure that helps.I will have to double check, I thought it was RVN that also used the gpu core.
