Eset nod 32 or eset smart security ?
Discussion in 'Networking & Security' started by kfoster, Feb 3, 2009.
  1. kfoster
    kfoster [H]Lite
    65
    Dec 17, 2008
    Looking at upgrading from mcafee to nod32 just wondering if its better to get the smart security package while im at it? I think the only advantage would be the spam filter ?
    Thanks
  2. Captain Colonoscopy
    Captain Colonoscopy 2[H]4U
    3,862
    Feb 19, 2004
    Depends, do you need the spam filtering in your mail client? Do you have a hardware firewall sitting in between your computer and DSL/Cable Modem? If you have a hardware firewall/NAT device then I wouldn't bother with it. The regular AV is all you should need.
  3. Phantoms
    Phantoms Limp Gawd
    303
    Nov 19, 2006
    To add to Captian, just run the stock Windows Software firewall with NOD32 if you have a hardware firewall (such as a router). If you don't have a hardware firewall, then the Smart Security may be worth the extra price.
