coldpower27
- Jan 27, 2005
NulloModo said:I don't recognize the bench used so I can't say anything about performance... but, if it works on a 975 board, does that mean the retail Kentsfield will likely run on the same boards and Conroe? If so that makes my Conroe upgrade choice easy if I can pop in a quadcore when they come out.
Yeh the timeframe is Q1 2007, so were looking at just before the introduction of the Bearlake and Weybridge ICH9 chipsets in Q2 2007.NulloModo said:I don't recognize the bench used so I can't say anything about performance... but, if it works on a 975 board, does that mean the retail Kentsfield will likely run on the same boards and Conroe? If so that makes my Conroe upgrade choice easy if I can pop in a quadcore when they come out.
coldpower27 said:Yeh the timeframe is Q1 2007, so were looking at just before the introduction of the Bearlake and Weybridge ICH9 chipsets in Q2 2007.
It will most likely work with 975X, I hope Intel didn't do some voltage thing again.
$BangforThe$ said:Ya but you will probably want DDR3 memory and Intel hasn't released a DDR2 memory controller yet that works with DDR3 memory
NulloModo said:Memory bandwidth isn't as important as CPU performance anymore really. Look at Conroe vs. X2s, the X2s have a far better memory bandwidth, yet still fall far behind.
$BangforThe$ said:Were talking about 4 cores here memory bandwidth will be important factor.
pxc said:I'll start drooling when he posts some benchmarks. It's pretty impressive that his sample is a 2.4GHz version so early.
Terra said:It could be a good sign that Intel is right on tracks with it's time table
Terra - Wonder how long they have been spitting retail Conroes out then
NulloModo said:Hehe it's sweet isn't it? Intel has a dual core CPU that can kill AMDs best and ES samples of quad-core chips way before they even have working silicon.
JetUsafMech said:Obviously it's fake...
Just wanted to chime in before duby229...heh.
Don't forget vis. I'm sure he'll be here with FUD soon.JetUsafMech said:Obviously it's fake...
Terra said:Something is not as it should be with the forum database...
I have seen several posts now that appear in the wrong order..all across the forum?
Terra...
NulloModo said:I think the intarweb is broken. I keep getting 'refused by host' errors over the past several days.
The god of the internets must be in a foul mood.
Terra said:So far the only place it have seen anything out of the ordinary is the post-switch-problem here on [H]ard.
Terra...
Lower FSB speed. The Conroe starts at 1066MHz FSB and the Merom starts at 667MHz FSB. At 2.95GHz the Conroe he used has a 368MHz FSB and at 2.96GHz the Merom he used has a 228MHz FSB. The details are posted on page 3.NulloModo said:Why did Merom take longer than Conroe in TMPG ?
The scaling is almost perfectly linear:
Single CPU: 63 seconds
Quad Core: 19 seconds
63/(19*4) = 0.82
So there is about an 18% decrease from theoretical max.
The 8 core AMD HT enabled system shows a 4.73x (best case) speed up with 8 cores.
4.73 / 8 = 0.59
Which is a 41% decrease from theoretical max.
Which one do you think is scaling better?
Terra said:I found this tidbit interesting:
Terra - That new architecture sure is well made
It will be a long time to see a 4 core opty scaling . 08. to long to wait on that.robberbaron said:Lets see a two-way Kensfield before we compare it to an 8 core Opteron. (or see a 4 core opteron's scaling)
$BangforThe$ said:It will be a long time to see a 4 core opty scaling . 08. to long to wait on that.
It is a newer CPU generation. What did you expect? It should be slower?cupholder2.0 said:HOLY SHIT. That thing ran 4x 1mb PI in 25secs, my PD [email protected] can do 1x 1mb in like 26 secs. Wow, the Kentsfeild can do 4 times as much work as my PD 950 in less time than my CPU .
that is the nice thing talking about future chips and technology, you don't need to prove anything. I do believe Coolaler's benches, but anything else I am taking with a huge grain of salt.robberbaron said:Prove it
Show me the 4 core opteron bench, please.
$BangforThe$ said:I think Duby went to AT forums . He did say he was working in IT.
Look at this post from IT Guy
http://forums.anandtech.com/messageview.aspx?catid=28&threadid=1880464&enterthread=y
pxc said:Don't forget vis. I'm sure he'll be here with FUD soon.
Like your post. I'll take advice from the expert on "mental defects."duby229 said:What fud? Asking questions is fud? WOW! You may need to see a doctor about that. If you believe everything you see, then it could cause some serious mental defects later in your life.
