So I downloaded a trial version of a utility that "ingests" photographs and renames them according to a user-selected scheme, like the filename starts with YYYYMMDD, for example.
When I tried to start the program, I got this errror message. The message also had an address for the access violation, plus the phrase "Last CP is 'LP5." So I did a google search and basically found nothing except some paid ads. The usual scamware, where you download a "free" program that costs you $40-$50 to actually fix the problem. These programs seemed to be like registry cleaners, and other cleanup utilities.
So I'm wondering if this is something I can fix myself. Any suggestions.
If it matters, the utility is called "Breeze Systems Downloader Pro."
Thanks.
Thanks.
