Enterprise Level Wireless (802.11b/g)
Discussion in 'Networking & Security' started by ShimmyT, Nov 21, 2005.
  1. ShimmyT
    ShimmyT Gawd
    608
    May 4, 2003
    I work inside of a fairly large building with a conference center (holds about 300 people). We are looking to put in a more robust wireless networking setup in. We would like to host events where the majority of the users bring in their own laptops, with our current users using their laptops. Currently we are running 3 Apple Airport Extremes over there now, and they do well for what we are doing now but we would like something that could provide us some reporting, and more enterprise style control. Also something that would have the power to have more then 10 or 15 users max would be nice. Any thoughts would be appreciated.
  2. figgie
    figgie [H]ardness Supreme
    7,820
    Feb 11, 2002
  3. Boscoh
    Boscoh [H]ard|Gawd
    1,161
    Nov 25, 2003
    I thought the Airport Extreme had a lot of enterprise-class management features...SNMP, 802.1x, LEAP support, a management app, etc. What exactly are you looking for?
    Your best bet for enterprise-class stuff is likely Cisco and Proxim. The Cisco 1240 and one of the Proxim 4000 series sound about right for your environment. But again, I'd investigate the Airport Extreme and make sure that you are not overlooking some management features, and dont kill your investment.
  4. Boscoh
    Boscoh [H]ard|Gawd
    1,161
    Nov 25, 2003
    Cool...I didnt know Extreme made wireless stuff...yeah, Extreme has some REALLY nice gear.
  5. Lazn_Work
    Lazn_Work [H]ardness Supreme
    5,621
    May 30, 2001
  6. ShimmyT
    ShimmyT Gawd
    608
    May 4, 2003
    The main problem we have with the Airport Extreme's are that they don't like to have more then 10 users on them. I was hoping there would be something with more power. Or maybe I am completely wrong in what is available out there.
  7. oakfan52
    oakfan52 [H]ard|Gawd
    1,578
    Oct 5, 2003
    WE use Aruba products in our enterprise.
  8. DESmack
    DESmack [H]Lite
    95
    Sep 1, 2004
  9. moetop
    moetop [H]ard|Gawd
    1,475
    Apr 8, 2004
    If your going to look at Cisco look at the new stuff. a long time ago they bought Aironet, and that was their standard.. Recently they bought Airspace, and from most indications that is going to be the way they go.
    So if your looking at Cisco and their management solutions, I would suggest looking at the airespace stuff.
    The WLSE and now the WCS for the Airespace stuff gives you a ton of ways to manageg your wireless network. Look here
  10. Boscoh
    Boscoh [H]ard|Gawd
    1,161
    Nov 25, 2003
    253 users on an 802.11g access point? Damn...that have to be pretty sluggish.
    I personally dont like going over 20 users on an access point. A lot less than that if you're looking at users moving files around the LAN a lot. But I come from more of a business environment, not large conference centers like you guys are dealing with.
  11. oakfan52
    1,578
    Oct 5, 2003
    that why we put an Aurba AP every 20' or so so they all over lap for fault tolerance and better load distrubution. Thats tough to do with Cisco because of the cost. Even for a Comant of our size (well over 250 IT employees).
  12. niccoli
    niccoli Limp Gawd
    432
    Feb 13, 2002
    Just put in a cisco wireless solution for a customer. Using a Cisco Wireless controller and Aironet 1200a/b/g, great solution, 802.1x and the wireless controller does rouge detection, wireless survey's and will automatically adjust wireless signal strength so your AP's don't overlap, also supports fast ap switching so users and wireless VoIP phones can roam from ap to ap.
  13. ShimmyT
    ShimmyT Gawd
    608
    May 4, 2003
    We're really trying to avoid the cisco route (damn marconi shit). I do like that 3com idea. What does everyone think about having just 4 airport extremes (another idea someone suggested) to handle the rooms? I'm just worried about too many people in one section jumping on one airport and it not load balancing properly.
  14. Boscoh
    Boscoh [H]ard|Gawd
    1,161
    Nov 25, 2003
    Maybe I missed something, but what "marconi shit" are you referring to?
  15. 1c3d0g
    1c3d0g 2[H]4U
    2,270
    Jun 7, 2004
    I recall M$ replacing all their model year 1999 Cisco networking gear with those Aruba products (which I found to be odd)...isn't Cisco supposed to be the best? :confused:
  16. Lazn_Work
    5,621
    May 30, 2001
    Nope Cisco is great for a single provider of everything, but in each niche there are better products.
    Foundry is better at enterprise security and 7 layer switching, Juniper is better at high end routers etc.
    But if you want a single provider, or if you are not high end enough to afford the above brands Cisco is hard to beat.
    ==>Lazn
