Balthazar2k4
CoreJizzer For Life
- Apr 17, 2009
Got my new Enermax Liqtech 360 on this morning and what a difference it makes. I was previously using the Corsair H100v2 so I don't know if what I am seeing is due to the move from 240mm to a 360mm radiator or the total coverage of the IHS on the 1950x @ 3.9ghz (1.275v). My temps have dropped from ~80C to ~65C at full load. I didn't check the flatness of the block and therefore did not do any lapping either. This is straight out of the box performance. I am not using the Enermax fans, but Corsair HD120 RGB in a standard three fan, push config. I am guessing performance might be improved with the Enermax fans as they are specified at a higher CFM and static pressure, but I got to have me some RGBs.
Anyways, just some observations after an hour of running at 100% load. Keep everyone posted should anything change.
