I think this is a "lomn is stupid and forgot a setting" problem, but I can't figure out what that setting might be.
At home, I've got a couple of WinXP Pro systems I'd like to be able to access remotely. I can VPN to the LAN and then run RDC from there. However, RDC will only successfully connect to one of the two systems. So far, I've not found any differences in settings on the two machines to explain it. One works, one doesn't. Here's the stuff I'm sure of on the "doesn't work" system.
Any ideas?
- No software firewall
- "Allow users to connect remotely" is checked.
- The user in question is on the allowed list (not that I can get this far)
- I can ping / see fileshares on the system via VPN, so that part is kosher.
Any ideas?
