rezerekted
- Apr 6, 2015
This used to work on Win7 fine. You create a shortcut to network connection and then you can enable/disable the connection with a right click of the shortcut. On Win8.1 doing the same thing only allows you to disable the connection and to enable it you have to select Open file location from the shortcut.
WTF Microsoft? To me it appears they deliberately sabotaged the ease of disco/enable the internet connection. Yes, I am calling it "sabotage".
